Назад竜 TatSu allows directives in the grammar that control the behavior of the generated parsers. All directives are of the form @@name :: <value>. For example:
@@ignorecase :: True
The directives supported by 竜 TatSu are described below.
@@grammar :: <word>¶Specifies the name of the grammar, and provides the base name for the classes in parser source-code generation.
@@comments :: <regexp>¶Specifies a regular expression to identify and exclude inline (bracketed) comments before the text is scanned by the parser. For (* ... *) comments:
@@comments :: /\(\*((?:.|\n)*?)\*\)/
@@eol_comments :: <regexp>¶Specifies a regular expression to identify and exclude end-of-line comments before the text is scanned by the parser. For # ... comments:
@@eol_comments :: /#([^\n]*?)$/
@@ignorecase :: <bool>¶If set to True makes 竜 TatSu not consider case when parsing tokens. Defaults to False:
@@keyword :: {<word>|<string>}+¶Specifies the list of strings or words that the grammar should consider as “keywords”. May appear more than once. See the Reserved Words and Keywords section for an explanation.
@@left_recursion :: <bool>¶Enables left-recursive rules in the grammar. See the Left Recursion sections for an explanation.
@@namechars :: <string>¶A list of (non-alfanumeric) characters that should be considered part of names when using the @@nameguard feature:
@@namechars :: '-_$'
@@nameguard :: <bool>¶When set to True, avoids matching tokens when the next character in the input sequence is alfarnumeric or a @@namechar. Defaults to True. See the ‘text’ expression for an explanation.
@@nameguard :: False
@@parseinfo :: <bool>¶When True, the parser will add parse information to every AST and Node generated by the parse under a parseinfo field. The information will include:
rule the rule name that parsed the nodepos the initial position for the node in the inputendpos the final position for the node in the inputline the initial input line number for the elementendline the final line number for the elementEnabling @@parseinfo will allow precise reporting over the input source-code while performing semantic actions.
@@whitespace :: <regexp>¶Provides a regular expression for the whitespace to be ignored by the parser. It defaults to /(?s)\s+/:
@@whitespace :: /[\t ]+/
