НазадМетки: airflow apache airflow
Use the GoogleCloudStorageToBigQueryOperator to execute a BigQuery load job.
airflow/contrib/example_dags/example_gcs_to_bq_operator.pyVIEW SOURCE
load_csv = gcs_to_bq.GoogleCloudStorageToBigQueryOperator(
task_id='gcs_to_bq_example',
bucket='cloud-samples-data',
source_objects=['bigquery/us-states/us-states.csv'],
destination_project_dataset_table='airflow_test.gcs_to_bq_table',
schema_fields=[
{'name': 'name', 'type': 'STRING', 'mode': 'NULLABLE'},
{'name': 'post_abbr', 'type': 'STRING', 'mode': 'NULLABLE'},
write_disposition='WRITE_TRUNCATE',
dag=dag)
Creates a new ACL entry on the specified bucket.
For parameter definition, take a look at GoogleCloudStorageBucketCreateAclEntryOperator
Some arguments in the example DAG are taken from the OS environment variables:
airflow/contrib/example_dags/example_gcs_acl.pyVIEW SOURCE
GCS_ACL_BUCKET = os.environ.get('GCS_ACL_BUCKET', 'example-bucket')
GCS_ACL_OBJECT = os.environ.get('GCS_ACL_OBJECT', 'example-object')
GCS_ACL_ENTITY = os.environ.get('GCS_ACL_ENTITY', 'example-entity')
GCS_ACL_BUCKET_ROLE = os.environ.get('GCS_ACL_BUCKET_ROLE', 'example-bucket-role')
GCS_ACL_OBJECT_ROLE = os.environ.get('GCS_ACL_OBJECT_ROLE', 'example-object-role')
gcs_bucket_create_acl_entry_task = GoogleCloudStorageBucketCreateAclEntryOperator(
bucket=GCS_ACL_BUCKET,
entity=GCS_ACL_ENTITY,
role=GCS_ACL_BUCKET_ROLE,
task_id="gcs_bucket_create_acl_entry_task"
template_fields = ('bucket', 'entity', 'role', 'user_project')
See Google Cloud Storage Documentation to create a new ACL entry for a bucket.
Creates a new ACL entry on the specified object.
For parameter definition, take a look at GoogleCloudStorageObjectCreateAclEntryOperator
gcs_object_create_acl_entry_task = GoogleCloudStorageObjectCreateAclEntryOperator(
object_name=GCS_ACL_OBJECT,
role=GCS_ACL_OBJECT_ROLE,
task_id="gcs_object_create_acl_entry_task"
template_fields = ('bucket', 'object_name', 'entity', 'role', 'generation',
'user_project')
See Google Cloud Storage insert documentation to create a ACL entry for ObjectAccess.
