Список вопросов ПечатьМетки: pxe dhcp загрузка системы stp
| RemiZOffAlex Создано: 2016-12-29 13:33:47.242436 Обновлено: 2016-12-29 13:33:47.242436 |
PXE boot (or dhcp) on guest failedIf a guest starts but is unable to acquire an IP address from DHCP and/or to boot using the PXE protocol, there are a few common causes: libvirt's iptables Rules OverriddenIf the guest is connected to one of libvirt's own virtual networks, libvirt adds several iptables rules to allow DHCP requests from the guest to reach the dnsmasq instance libvirt runs on the host for that virtual network. Unfortunately, there are several management applications that add/remove iptables rules, and there is currently no central controlling authority to make sure that these programs (including libvirt itself) don't add rules that override (or sometimes even completely remove) the rules added by others. SolutionTo see if this is the cause of your problem, simply restart the libvirtd service: # service libvirtd restart When libvirtd is restarted it will reload all of its iptables rules, putting them in the proper order relative to other rules so that guest traffic will once again be allowed. If this solves your problem, but it recurs later, try to figure out what iptables-related application was run prior to the failure (usually it will be some sort of firewall management application), and and remember to restart libvirtd after it's run in the future. The long term solution to this problem will be in the form of the firewalld project, which is intended to become the above mentioned "central controlling authority". At the moment, though, firewalld itself creates exactly this problem - if you are experiencing this problem and firewalld is enabled, stop and disable it, then restart libvirtd: # service firewalld stop # service firewalld disable # service libvirtd restart Long Forward Delay Time on BridgeThis is by far the most common. If the guest network interface is connecting to a bridge device that has STP (Spanning Tree Protocol) enabled, and a long "forward delay", the bridge will not forward packets from the guest onto the bridge until at least $forwardDelay seconds have elapsed since the guest was connected to the bridge (this delay gives the bridge time to watch the traffic from the interface and determine what mac addresses are behind it, to prevent forwarding loops in the network topology). If the forward delay is longer than the timeout of the guest's PXE/DHCP client, then the client's operation will fail, and the guest will either fail to boot (in the case of PXE) or fail to acquire an IP address (in the case of DHCP). SolutionTo solve this problem, you should change the forward delay on the bridge to 0, and/or disable STP on the bridge (note that this is only good advice if the bridge is not used to connect multiple networks, but just to connect multiple endpoints to a single network (the most common use case for bridges used by libvirt)). If the guest in question has interfaces connecting to a libvirt-managed virtual network, you can accomplish this by editing the definition for the network, and restarting it, e.g. for the default network: # virsh net-edit default Add the following attributes to the <bridge> element: <bridge name='virbr0' delay='0' stp='on'/> (note that delay='0' and stp='on' are actually the default settings for virtual networks, so you will probably only need to do this to change to some othervalue in case the configuration has already been modified from the default) If the guest interface is connected to a host bridge (one configureed outside of libvirt), the method of changing the delay depends on the Linux distro you are using: Fedora/RHEL/SuseEdit the file /etc/sysconfig/network-scripts/ifcfg-${brname} (where ${brname} is the name of the bridge device the guest is connecting to) and add/edit the following lines to turn STP on with a 0 second delay: STP=on DELAY=0 Debian/UbuntuEdit /etc/network/interfaces and find the section that configures ${brname}. Add/edit the following lines: bridge_stp on bridge_maxwait 0 All distrosAfter changing the config, restart the bridge device:
/sbin/ifdown ${brname}
/sbin/ifup ${brname}
CaveatUnfortunately, even if you set the forward delay on ${brname} to 0, if it is not the "root bridge" in the network, it will eventually have its delay time set to the delay configured for the root bridge. In this case, currently the only solution is to disable STP completely on ${brname}. iptables/kernel doesn't support CHECKSUM mangling rulesThis is only a problem if all four of the following are true: 1) your guest is using virtio network devices (the config will have "<model type='virtio/>") 2) the host has the "vhost-net" module loaded ("ls /dev/vhost-net" will not return an empty result). 3) The iptables version on the host is older than 1.4.10, which added the libxt_CHECKSUM extension. You will know this is the case if you see the following message in libvirtd's logs: warning: Could not add rule to fixup DHCP response checksums on network 'default' warning: May need to update iptables package & kernel to support CHECKSUM rule. (IMPORTANT NOTE: Unless the other 3 points in this list are also true, the above warning message is completely innocuous, and is not an indicator of any other problems!) 4) The guest is attempting to get an IP address from a DHCP server that is running directly on the host. The problem is that the vhost-net path for packets causes UDP packets destined for the guest that originate on the host the guests to have uncomputed checksums. The result is that the guest's network stack sees the packet as invalid, and discards it. SolutionTo solve this problem, you can invalidate any of the four points above. If it's possible to update the host iptables and kernel to iptables-1,4.10+, that is the best solution. Otherwise, the most specific fix is to disable the vhost-net driver for this particular guest. To do that, you need to edit the configuration for the guest:
virsh edit ${guestname}
and change/add a <driver> line to the <interface> section:
<interface type='network'>
<model type='virtio'/>
<driver name='qemu'/>
</interface>
After you save the change, shutdown the guest, then restart it. |
